Becky70
Message 1 of 8
Smart plug not connecting after upgrade
Hi
I've just upgraded to a Smart Hub 2. My Google homes have all connected well but my smart sockets have not.
I've split my signal and turned off 5GHZ but the sockets are still not connecting
Any ideas from anyone?
7 REPLIES 7
Keith_Beddoe
Message 2 of 8
Re: Smart plug not connecting after upgrade
What was the reason for upgrading, was the original home hub faulty?
The Smart Hub 2 does not allow you to split the SSIDs.
This similar post may help https://community.bt.com/t5/Home-setup-Wi-Fi-network/Can-not-connect-Tuya-smart-plugs-to-BT-hub-2/m-...
Anonymous
Not applicable
Message 3 of 8
Have you checked the hub manager to confirm that they're not connected or are you assuming they're not connected because you can't contact them?
Assuming that they're cloud based, you may need to check the app settings
Becky70
Message 4 of 8
No it was just an upgrade. We turned the 5GHZ off. It allowed us to do that but to no avail.
I'll check out the link you attached
Many thanks for info
Becky70
Message 5 of 8
Not sure. When I've tried to connect them to the new wifi signal they keep giving error in network message. The 3 sockets I have worked perfectly fine on old network.
There doesn't seem to be any setting in the Smart Life app to change.
Anonymous
Not applicable
Message 6 of 8
At a guess, your smartplugs are searching for your old SSID but of course they can't find it because it's not there, You could try changing the SSID and wi-fi password of your new router to be the same as your previous one. If I'm right your plugs will then connect.
Becky70
Message 7 of 8
Now that's a brilliant idea! I'll give that a go.
Fingers crossed!
Becky70
Message 8 of 8
Just wanted to thank all the advice I received from everyone
Got things sorted now. I turned off the 5Ghz in the hub manager. Turned the hub on and off again. Connected all of my sockets and then turned the 5Ghz signal back on. All is now working smoothly!  Yay!
