lnajr02
Recognised Expert
Message 11 of 17
Re: Smart plugs and Powerline500
Who makes the smart plugs ?
Aok
Message 12 of 17
I got them from Amazon.  Make is Teckin.
lnajr02
Recognised Expert
Message 13 of 17
I agree with the views below, BT recommend that the Powerline extenders are not installed on extension leads so a switched supply (Smart Plug Wi-fi Outlet that Works with Amazon Alexa, Google Home) can not be good. Can I ask Why are you using them the power consumption of the Powerline 500 Flex is only 2.7 W Operation , 1.6 W when Idle and 0.34 W in power saving mode
Aok
Message 14 of 17
I am not using the smartplug on the powerline plug.  Apologies if I gave this impression.
The powerline plugs are plugged into the wall socket.  The smart plugs are used elsewhere in the house to control other devices.
licquorice
Message 15 of 17
I assumed you were using them elsewhere. If they are causing interference it won't matter where they are plugged in, the whole ring main will be affected.
BenHorley
Message 16 of 17
Hello
I have exactly the same issue with the same make of smart plugs though my powerline adapters are brand new TP-Link ones. I can buy new smart plugs if I really have to, I can see that there's a TP-Link 4-pack for £30 but I don't want to get exactly the same problem with new plugs, did you end up getting new ones and did they work?
Cheers
Ben
Dode
Expert
Message 17 of 17
I am using the BT500 Powerline  plugs and I also have quite a few TPlink smart plugs scattered around and I am not having any issues.
