Airtanker
Newbie
Message 1 of 7
Smarthub2
Why does the wifi keep switching to 4g from wifi.
6 REPLIES 6
DiggerOfTrenches
Message 2 of 7
Re: Smarthub2
4G with BT plus?
Message 3 of 7
Re: Smarthub2
is it one of your wireless devices that keeps switching from wifi to 4g?  if so you probably have it set in your setting to slect the strongest signal hence why it keeps changing  I turned it off in my mobile as it was annoying
Airtanker
Newbie
Message 4 of 7
Re: Smarthub2
Thankyou. I have Samsung s9. How do you switch it off please
Message 5 of 7
Re: Smarthub2
Settings, connection,wifi, advanced,  turn off switch to mobile data
Airtanker
Newbie
Message 6 of 7
Re: Smarthub2
Thankyou
DiggerOfTrenches
Message 7 of 7
Re: Smarthub2
Thumbs up for sorting that on based on OP.  Don't keep a smart phone so no help there then.
