freezing77
Newbie
Message 1 of 9
Socket placement
I wish to transfer to BT,  I want my modem/fibre installed on the second floor and not the ground floor. Is this something BT do.
TIA
8 REPLIES 8
Message 2 of 9
Re: Socket placement
Welcome to this user forum.
Do you already have an existing broadband service connected to a phone socket?
freezing77
Newbie
Message 3 of 9
No I currently have Virgin fibre on the second floor.
Message 4 of 9
Is there an existing BT or Openreach labelled box elsewhere in the house, as Openreach would not use your Virgin Media wiring?
freezing77
Newbie
Message 5 of 9
I have three telephone sockets on the ground floor, one marked Virgin the other two unmarked. One was used for ADSL some many years ago from BT. The reason I moved to Virgin was for faster internet as the ADSL line could only support something like 2-3 mbps.
My fibre comes into the house directly on the second floor and is wired from the outside junction box at ground level to the second floor.
Message 6 of 9
I would expect that Openreach would use the existing socket that was originally used for ADSL.
What product are you going to order from BT Retail?
I assumed the Virgin connection is a cable connection, but it may well be fibre now. That network would belong to Virgin Media.
freezing77
Newbie
Message 7 of 9
Going to go for BT Superfast Fibre
Message 8 of 9
if you use your address then this should give indication of expected speed range
https://www.btwholesale.com/includes/adsl/main.html
Message 9 of 9
Then Openreach would still use the original socket if it was still live. It depends on where the Openreach network enters the house. If it overhead, then there may be a better chance of getting a new socket fitted.
If it comes in underground, then you would have to run an extension cable yourself, or relocate the home hub downstairs.
