ofwrose
Message 1 of 7
Solid orange phone light on BT Hub
On my BT hub all the lights are blue apart from the phone light, which is a solid orange. I still have a broadband connection and can access the internet however this has caused some connection issues that weren't a problem when it was solid blue.
I realise this has something to do with BT Talk. I have looked at all my wires and nothing is loose or unconnected.
Does anyone know how I can change this so it is solid blue again?
6 REPLIES 6
Message 2 of 7
Re: Solid orange phone light on BT Hub
have you changed your contract recently ? if you have the BB Talk will have been cancelled
ofwrose
Message 3 of 7
Thanks for replying
No, it's been the same since we first got the hub
Message 4 of 7
did you ever activate broadband talk
ofwrose
Message 5 of 7
Yes, I'm pretty sure we did since the light was a solid blue before and we never had connection issues
Message 6 of 7
it sounds like BBThas been deactivated and it should cause no problem to the normal Broadband connection
ofwrose
Message 7 of 7
I will re activate from the bt website
thanks
