gideoncresswell
Message 1 of 6
Some websites only working if I use a VPN
I wonder if any one could help with this issue as I am finding there are certain websites that I only seem to be able to connect to from my home network if I turn on a VPN (e.g. NordVPN).
I'm finding this issue is affecting all devices connected to my home network and none of them can see certain sites unless I connect to a VPN.
I have of course reset my router and all devices but I was wondering if there is some kind of caching happening and if I can flush it on the hub manager?
Thanks.
5 REPLIES 5
ozsat
Recognised Expert
Message 2 of 6
Re: Some websites only working if I use a VPN
Is it Nord VPN you are using?  I had a similar issue with ExpressVPN which turned out to be a settings issue in the VPN even though it should not have been looking at the VPN.
Thanks.
Fibre 2 Unlimited using BT Hub 6A with BT TV Box Pro (UHD/HDR) via 5GHz WiFi.
gideoncresswell
Message 3 of 6
Yes I am using Nord VPN.
TimCurtis
Guru
Message 4 of 6
@gideoncresswell
I've just been experiencing this with Euro Car Parts.
I don't use any BT equipment or DNS servers. I use an Asus & either google or OpenDNS but cannot connect to the above website. However , using any VPN I can connect instantly.
Very strange. Doesn't help you but you're not alone.
gg30340
Message 5 of 6
TimCurtis
Guru
Message 6 of 6
Not for me. Still the same.
