Global1
Newbie
Message 1 of 4
Something keeps knocking out Port 2 on my BT Home Hub 5 at 7pm on Thursdays - Any ideas?
3 REPLIES 3
Message 2 of 4
Re: Something keeps knocking out Port 2 on my BT Home Hub 5 at 7pm on Thursdays - Any ideas?
Seems very specific 7pm on Thursdays sounds like problem with on of your connected devices
Global1
Newbie
Message 3 of 4
Thanks for response but it was ok the week after and then started again this Thursday...so not so sure.
S
V_Meldrew
Recognised Expert
Message 4 of 4
Swap the cable going into port 2 with that from one of the other ports and see if the fault moves, if it does then your device is faulty, if it remains with port 2 then you have a very strange problem with your hub
