Message 1 of 2
Speaker keeps disappearing from its app with Smart Hub 2
Hi,
I have a recurring issue of my stereo being intermittently invisible to the app that controls it (Naim is the manufacturer).
This was solved by a software update a few months back (Sonos speakers were having the same issue I believe), but the software has been updated again and the problem has returned.
Currently my SH2 is on v0.30.01.08093-BT
Does anybody happen to have a similar issue and a solution?
Is there another software update I coming?
I'm beginning to think that I have a faulty router
Thanks for any advice.
1 REPLY 1
Message 2 of 2
Re: Speaker keeps disappearing from its app with Smart Hub 2
Same here. But again problems with Sonos. It was ok since November update, but last update ruined it again. I can see that there are more issues than last time.
