Message 1 of 1
Speed Issues - Home Plug - Any connection?
Have very recently started suffering exterme drops in connection speed.  Going from 32M to under 1!  The only thing I have noticed is that if I disconnect the HomePlug cable from my Netgear router, there seems to be an improvement but I am not sure this isn't just conincidence.
The only way to get speeds bakc up is to unplug the router etc.  It then gradually improves.
Nothing else has changed so before I put aside three days to contact BT, I wondered if anyone had any ideas?
