SNOWDROP252
Message 1 of 5
Speed Test results...strange message appearing
Could anyone please enlighten me as to why I and many people near to me are receiving this message when they do a Speed Test and opt for further diagnostics? It has only happened within the last couple of months.
4 REPLIES 4
Message 2 of 5
Re: Speed Test results...strange message appearing
that message often appears but you probably find if you wait a day or so and try again that btspeedtester works ok
SNOWDROP252
Message 3 of 5
Thanks for your reply...however it has been like that in this area for a few months now.....is it anything I should worry about or report?
Message 4 of 5
No it is nothing to worry about and nothing you can report as BT Wholesale do not deal directly with the public
SNOWDROP252
Message 5 of 5
Many thanks to those that replied. Problem solved,
