grahamstaddon
Message 1 of 4
Speed issues
Hi guys have had infinity now finally for a couple of months and to be honest im not blown away by it and todays speedtest has shown me why my pages are very slow to load.
1. Best Effort Test: -provides background information.
 Download Speed
 11.71 Mbps
0 Mbps77.43 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 11.71 Mbps
 For your connection, the acceptable range of speedsis 60 Mbps-77.43 Mbps .
 Additional Information:
 IP Profile for your line is - 77.43 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 9.93 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 9.93Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
Is there anything i can try?
Thanks.
Graham.
3 REPLIES 3
Distinguished Guru
Message 2 of 4
Re: Speed issues
To be honest, your IP Profile doesn't show a problem.
Are your problems wired ethernet or wireless?
If not, I'll try again 🙂
grahamstaddon
Message 3 of 4
Re: Speed issues
Every device is wireless as the hub is downstairs and the pc is upstairs
grahamstaddon
Message 4 of 4
Re: Speed issues
Maybe because its wireless i guess, hardwiring cat 5 stuff isnt really a neat enough option though perhaps my netgear n adaptor isnt good enough since the upgrade to infinity
