Message 11 of 14
Re: Splitting BT Hubs SSID (Wireless name)
Yes indeed ...the smart plug just does not seem to like my wireless password for some reason.
Message 12 of 14
The smart plugs are called Eightree...got them off Amazon.
Message 13 of 14
Thanks..I will try your suggestion
Message 14 of 14
So, these are Tuya (Smart Home) devices with an Amazon psudo-branding.  Initial connection is via Bluetooth, and you shouldn't normally need to turn off the 5GHz radio.  I've set these very devices up though I don't have any here, and they are usually incredibly straightforward.
Are you using the Tuya, Smart Home, or another app?  From memory, the Tuya app itself is usually at least a point version ahead of the others!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
