TR21
Newbie
Message 1 of 3
Stable connection set up
Hello I am here basically to find out if there are posibilities of having a custome set in another words I want make personal set up to make lot more better stable and better conection to the broadband. I do have the latest router from BT genuinly I find that BT routers arent the most reliable to use so was looking for possible sugestion which would improve the stability of my broadband. The line speeds which I have is basically 37Down and 6-7UP, I would like to invest into my network to make it a loot better.
I would be looking for possible sugestions and solutions to what would be best setups and devices required to set up a better network in the household.
Regards: TR21
2 REPLIES 2
Message 2 of 3
Re: Stable connection set up
Why is your current setup unstable?
Are you connecting to the home hub using an Ethernet connection, or a wireless connection, as wireless is never going to be 100% stable?
You are of course free to use a different router, which may give you other options.
Message 3 of 3
can you post stats from your hub  if hh6 then advanced settings then technical log information
can you enter your phone number and post results  delete number  https://www.btwholesale.com/includes/adsl/main.html
check for line noise   dial 17070 option 2  should be silenet and best with corded phone
