rizla13
Message 1 of 11
Standalone modem settings
Hi
I recently purchased a standalone modem (Zyxel VMG1312-B10A) so i can use my own router
I am on Bt infinity 2 80/20
would anyone know what settings i need to apply to use the modem?  I have been reading around and there are mixed settings people use to connect the modem to bt service and i dont want to use the incorrect settings and then have problems with the internet
If anyone can help i would appreciate it
thanks
10 REPLIES 10
licquorice
Message 2 of 11
Re: Standalone modem settings
I don't know what settings are available on the Zyxel, but they will either work or not work rather than give problems so just try them.
The Zyxel experts are over on Kitz.
rizla13
Message 3 of 11
Thank you
rizla13
Message 4 of 11
Just out of curiosity, as the bt business hubs have modem mode, can they be used for residential internet and be used in modem mode?
licquorice
Message 5 of 11
rizla13
Message 6 of 11
Thanks. And will the firmware of the hub still get updated if it’s connected to residential internet?
Also is the settings same as a residential hub like username and password. Will it be just and play?
licquorice
Message 7 of 11
Clearly the settings will be different, the residential hub is a plug and play modem/ router, you are wanting to use the business hub as a modem. The first thing you would need to do is put it in bridge mode.
PPPoE username and password is a function of the router, not the modem.
rizla13
Message 8 of 11
Ok thanks. Will the firmware of the hub still update ?
licquorice
Message 9 of 11
Sorry, no idea.
brookheather
Expert
Message 10 of 11
Probably not as the firmware updates are sent using the TR-069 protocol and I don't think the BT hub in modem mode would "see" these connections.
