Showing results forΒ
Search instead forΒ
Did you mean:Β
mossywell
Message 21 of 35
Re: Strange HH5 TR069 Log entries.
@scott_johnston: Are you getting any problems with wifi?
@Ribblelancs: I can't reproduce your problem unfortunately as I always get HTTP authentication success. 😞
The problem I have is this as per below. And whenever I speak to BT, they claim that it's because every device in the house gets sudden interference bad enough to cause a complete disconnect every half an hour. Mentioning the fact that it is accompanied by TR069 just gets a pause followed by a "which computer are you seeing this TR069 error on?". πŸ˜•
12/02/2015 00:09:11, Media Disconnected, 00:05:06
12/02/2015 00:39:15, Media Disconnected, 00:00:19
12/02/2015 01:09:09, Media Disconnected, 00:00:11
12/02/2015 01:39:11, Media Disconnected, 00:00:20
12/02/2015 02:09:14, Media Disconnected, 00:00:05
12/02/2015 02:39:12, Media Disconnected, 00:00:57
12/02/2015 03:09:11, Media Disconnected, 00:00:09
12/02/2015 03:39:14, Media Disconnected, 00:00:20
12/02/2015 04:09:13, Media Disconnected, 00:00:05
12/02/2015 04:39:16, Media Disconnected, 00:03:36
12/02/2015 05:09:13, Media Disconnected, 00:05:06
12/02/2015 05:39:12, Media Disconnected, 00:03:32
12/02/2015 06:09:16, Media Disconnected, 00:00:08
This was after a suggestion to disable 5Ghz  - didn't make any difference. Sigh...
Was: BT Home Hub 5 (Type A) | Software version 4.7.5.1.83.8.204 | Last updated 21/01/15
Then: BT Home Hub 5 (Type A) | Software version 4.7.5.1.83.8.173.1.6 | Last updated Unknown
Now: BT Home Hub 5 (Type A) | Software version 4.7.5.1.83.8.204 | Last updated 17/02/15
Distinguished Expert
Message 22 of 35
@mossywell wrote:
@@scott_johnstonn: Are you getting any problems with wifi?
@@Ribblelancs: I can't reproduce your problem unfortunately as I always get HTTP authentication success. 😞
You'll just have to tolerate it without losing your cool. A distinct pattern of events is emerging.
Something will be done.............
mossywell
Message 23 of 35
LOL - one of the agents remarked that, given the problems I'm having, I was remarkably calm. I said that I didn't feel it inside!
I think you're right about it being fixed eventually, but I would like to know if it's a known problem. The problem is that even if it is, they'll say that I'm the only person with the problem. πŸ˜•
scott_johnston
Message 24 of 35
I am lucky at the moment it's not causing any broadband disconnects currently at 2 days 21hrs dsl uptime but I will probably reset the router because family members will reset the router when they can't connect via wifi. I would rather reset the hh5 in the morning and hopefully it will not need reset again at least for today. I have been trying to prove my issue isn't interference by using inssider and showing signal strength and when wifi devices disconnect they won't reconnect even when next to the router.
TR069 Logs Today
08:22:46, 12 Feb.(250397.740000) CWMP: Set Parameter by TR069 Success
08:22:25, 12 Feb.(250376.420000) CWMP: Set Parameter by TR069 Success
07:53:08, 12 Feb.(248619.670000) CWMP: Set Parameter by TR069 Success
07:52:47, 12 Feb.(248598.360000) CWMP: Set Parameter by TR069 Success
07:52:45, 12 Feb.(248596.530000) CWMP: Set Parameter by TR069 Success
07:52:24, 12 Feb.(248575.210000) CWMP: Set Parameter by TR069 Success
07:23:07, 12 Feb.(246818.750000) CWMP: Set Parameter by TR069 Success
07:22:46, 12 Feb.(246797.440000) CWMP: Set Parameter by TR069 Success
07:22:44, 12 Feb.(246795.670000) CWMP: Set Parameter by TR069 Success
07:22:23, 12 Feb.(246774.350000) CWMP: Set Parameter by TR069 Success
06:53:06, 12 Feb.(245017.700000) CWMP: Set Parameter by TR069 Success
06:52:44, 12 Feb.(244995.730000) CWMP: Set Parameter by TR069 Success
06:52:42, 12 Feb.(244993.530000) CWMP: Set Parameter by TR069 Success
06:52:21, 12 Feb.(244972.220000) CWMP: Set Parameter by TR069 Success
06:23:11, 12 Feb.(243222.360000) CWMP: Set Parameter by TR069 Success
06:22:50, 12 Feb.(243201.060000) CWMP: Set Parameter by TR069 Success
06:22:48, 12 Feb.(243199.170000) CWMP: Set Parameter by TR069 Success
06:22:26, 12 Feb.(243177.430000) CWMP: Set Parameter by TR069 Success
05:23:08, 12 Feb.(239619.440000) CWMP: Set Parameter by TR069 Success
05:22:45, 12 Feb.(239596.760000) CWMP: Set Parameter by TR069 Success
05:22:43, 12 Feb.(239594.880000) CWMP: Set Parameter by TR069 Success
05:22:22, 12 Feb.(239573.570000) CWMP: Set Parameter by TR069 Success
04:53:04, 12 Feb.(237815.550000) CWMP: Set Parameter by TR069 Success
04:52:43, 12 Feb.(237794.250000) CWMP: Set Parameter by TR069 Success
04:52:41, 12 Feb.(237792.470000) CWMP: Set Parameter by TR069 Success
04:52:20, 12 Feb.(237771.160000) CWMP: Set Parameter by TR069 Success
04:23:09, 12 Feb.(236020.690000) CWMP: Set Parameter by TR069 Success
04:22:48, 12 Feb.(235999.390000) CWMP: Set Parameter by TR069 Success
04:22:46, 12 Feb.(235997.620000) CWMP: Set Parameter by TR069 Success
04:22:25, 12 Feb.(235976.310000) CWMP: Set Parameter by TR069 Success
03:53:07, 12 Feb.(234218.790000) CWMP: Set Parameter by TR069 Success
03:52:46, 12 Feb.(234197.490000) CWMP: Set Parameter by TR069 Success
03:52:44, 12 Feb.(234195.720000) CWMP: Set Parameter by TR069 Success
03:52:23, 12 Feb.(234174.410000) CWMP: Set Parameter by TR069 Success
03:22:42, 12 Feb.(232393.950000) CWMP: Set Parameter by TR069 Success
03:22:21, 12 Feb.(232372.640000) CWMP: Set Parameter by TR069 Success
02:53:03, 12 Feb.(230614.620000) CWMP: Set Parameter by TR069 Success
02:52:42, 12 Feb.(230593.320000) CWMP: Set Parameter by TR069 Success
02:52:40, 12 Feb.(230591.520000) CWMP: Set Parameter by TR069 Success
02:52:19, 12 Feb.(230570.180000) CWMP: Set Parameter by TR069 Success
Message 25 of 35
They are all good at face to face (or ear to ear) PR.
Not surprising since UK does'nt manufacture much any more. Sales and PR is all that's left. OH - and project management.
scott_johnston
Message 26 of 35
21:03:31, 09 Feb.(46440.150000) CWMP: Download file, FileType=4, FileName=5a-​DR-​SpeedTester-​v1.6.tar.gz.aes.rsa.signed, Username=, CommandKey=1926829465
I wondering at the minute If i used the online chat maybe they could speed up the process of remotely upgrading the hh5 to v1.6 like Ribblelancs then we will be ready for the next update. Instead of downloading>installing v1.4 then doing the same for v1.6. because i'm not sure if v1.4 and the M Download have been installed or just downloaded to hub. The latest firmware .204 didn't install for weeks and only installed after shutting down the hub before turning the electricity off to change a power socket.
Message 27 of 35
Sorry for the outburst.
Here's the moment at which the problems started again. There's been no more wifi dropouts in the past hour.
01:43:50, 12 Feb.(236053.150000) PPPoE is up -​ Down Rate=51538000Kbps, Up Rate=11699000Kbps; SNR Margin Down=6.7dB, Up=6.2dB
01:43:50, 12 Feb.(236053.140000) CHAP authentication successful
01:43:50, 12 Feb.(236053.060000) CHAP Receive Challenge
01:43:50, 12 Feb.(236053.050000) Starting CHAP authentication with peer
01:43:50, 12 Feb.(236053.050000) PPP LCP Receive Configuration ACK
01:43:50, 12 Feb.(236053.050000) PPP LCP Send Configuration ACK
01:43:50, 12 Feb.(236053.050000) PPP LCP Receive Configuration Request
01:43:50, 12 Feb.(236053.050000) PPP LCP Send Configuration Request
01:43:50, 12 Feb.(236053.050000) PPP LCP Receive Configuration Reject
01:43:49, 12 Feb.(236051.740000) PPP LCP Send Configuration ACK
01:43:49, 12 Feb.(236051.740000) PPP LCP Receive Configuration Request
01:43:48, 12 Feb.(236051.000000) PPP LCP Send Configuration Request
01:43:45, 12 Feb.(236047.680000) PTM over DSL is down after 0 minutes uptime
01:43:42, 12 Feb.(236044.720000) PTM over DSL is up
01:43:40, 12 Feb.(236042.720000) PPPoE is down after 3931 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
01:43:35, 12 Feb.(236038.230000) PPP LCP Send Termination Request [User request]
I don't quite understand the meaning or reason for WAN Ethernet 2 - Down. Must be internal to the HH5.
Dode
Message 28 of 35
Maybe someone can explane some more strange entries. Only happened since the .204 update. Check the dates.
Edit.
scott_johnston
Message 29 of 35
I would delete the mac addresses from the posted screenshot
Dode
Message 30 of 35
Thanks, I have just left the dates there which are the strange entry.
