Showing results forย
Search instead forย
Did you mean:ย
mossywell
Message 31 of 35
Re: Strange HH5 TR069 Log entries.
@Ribblelancs wrote:
I don't quite understand the meaning or reason for WAN Ethernet 2 - Down. Must be internal to the HH5.
I would presume that the E of PPPoE is marked as down, though why it is "2", is the "2" just the code for "down" (rather than "ethernet 2")? That said, I haven't seen any "PPPoE is down after xxx minutes uptime" on mine, so can't confirm.
I'm on 4.7.5.1.83.8.204 - sorry, I should have said. ๐Ÿ™‚
Was: BT Home Hub 5 (Type A) | Software version 4.7.5.1.83.8.204 | Last updated 21/01/15
Then: BT Home Hub 5 (Type A) | Software version 4.7.5.1.83.8.173.1.6 | Last updated Unknown
Now: BT Home Hub 5 (Type A) | Software version 4.7.5.1.83.8.204 | Last updated 17/02/15
Distinguished Expert
Message 32 of 35
There are no problems this morning. No DSL disconnects, wifi is ok.
Last "Value Change " event was at 21-09 pm yesterday, 12-02-2015.
mossywell
Message 33 of 35
Belated reply.
My problem was solved by a new HH5 router. It is unclear as to why this fixed it but BT (after over 2 weeks of calls) suspected that it was a failed firmware upgrade where the HH5 shows the new version but inside not all is well. I wonder how many other problems that materialise soon after a firmware update are caused by the same problem?!
Message 34 of 35
@mossewell,
Thanks for the post.
The "fix" was successfully applied, so it's a slight improvement over a situation which slowly built up (by stealth) from January this year.
It's really back to where it was on initial HH5 install in July 2014. Stalemate.
MrBelter
Expert
Message 35 of 35
@mossywell wrote:
Belated reply.
Hmmm my HH5 Type A is acting up like a right burk, with many, many TR069 log entrys and reboots and it has all come about since the 4.7.5.1.83.8.222.1.1 firmware started floating about (which my HH has not updated to).
