pootler
Message 1 of 5
Strange case of changing broadband network address?
Hello - I am new to the forums and would appreciate any advice concerning this enquiry.
We recently got Bt infinity.
All seems well and we have good speed- - we have only been connected for a month.
Recently though a couple of times we have suddenly lost connection, or the connection seems to struggle to connect- this is with the home hub 5.
I  am not that technical regarding routers, but my current set up is with the home hub providing our personal network and then we have another router ( lan > Wan) that is used to provide wifi to guests in our adjacent holiday let. This router has dd-wrt installed and is set up to restrict bandwidth to guests. All works well.
However as mentioned recently the connection seems to drop - and also the guest network drops out as well.
I noticed that if I tried a speed test at this time that the IP address had changed to something unrecognisable.
Connecting and reconnecting on the hub usuually solves  it - but I  don't know why it happens?
Here  are the details when everything seems ''normal''
Internet Connection Configuration
Connection Information
Connection time:
0 days, 02:14:43
Data Transmitted/Received:
24.1 MB / 170.3 MB
Broadband username:
bthomehub@btbroadband.com
Password:
Not configured
TCP/IP settings
Broadband network IP address:
109.146.233.191
Default gateway:
217.32.145.11
Primary DNS:
194.72.0.98
Secondary DNS:
62.6.40.178
 And here are the details when thing start to lose connection:
Connection time:
0 days, 00:14:45
16.5 MB / 67.5 MB
Broadband username:
Password:
Not configured
TCP/IP settings
81.155.135.58
Default gateway:
217.32.145.11
Primary DNS:
194.72.0.98
Secondary DNS:
62.6.40.178
... Is that   ''different''  broadband Ip address normal - or not?
If anyone can explain in relatively layman terms 🙂 - I would be very grateful
Pootler
4 REPLIES 4
Message 2 of 5
Re: Strange case of changing broadband network address?
the address belongs to BT
pootler
Message 3 of 5
Thanks  john46,
....but why would the address suddenly change for no reason?
Many thanks
pootler
Message 4 of 5
Your IP address is dynamically assigned by BT, and will change each time there is a disconnection, or maintenance on the network.
pootler
Message 5 of 5
THanks keith!.
