Guybrush3
Message 1 of 10
Streaming destroys ping
I've looked on this forum a bit and seen it a few times but cant find any solutions other then change ISP.
30Mbps Download
9Mbps Upload
PingPlotter I didn't know if any of the data is private so i just blanked it.
Where do I go from here its unbearable to use and is probably top 2 reasons for having internet gaming+streaming.
9 REPLIES 9
Moderator
Moderator
Message 2 of 10
Re: Streaming destroys ping
@Guybrush3,  I'm really sorry to see you're having problems with your connection when streaming and gaming at the same time. I've sent you a private message with details on how to get in touch with the moderation team and we'll be happy to help.
cowo8
Message 3 of 10
check the similar threads on the front page, i've been through standard support and up to executive resolutions with nothing positive so far. seems like a problem just with the BT network, i've been looking at other ISPs to switch to
Guybrush3
Message 4 of 10
Bt contacted us and said it would be fixed within a day, sounds like the knew exactly what the issue was, it hasn't worked and now BT have been radio silent. is there a case to get out of contract if they aren't supplying usable internet?
Moderator
Moderator
Message 5 of 10
Hi @Guybrush3,
Thanks for taking the time to post.
I'm sorry that you feel we have gone radio silent on you, this is far from the case. I can see that @RobbieMac has been working away in the background with our network team trying to find a fix to this issue for you. I will let Robbie know you are waiting on an update.
Matt
Guybrush3
Message 6 of 10
Any updates yet guys?
Moderator
Moderator
Message 7 of 10
Hi @Guybrush3,
I have sent you a PM.
Matt
Guybrush3
Message 8 of 10
Hey @Matt-S  the changes you made seem to have made things a little better, its still unplayable but its down from 400ms to about 100-200ms if you got anything else you can do we might get there lol.
why is this happening? I assume its purposeful for it to effect so many people?
Moderator
Moderator
Message 9 of 10
Hi @Guybrush3, I'm sorry to see you're still experiencing problems after the changes @Matt-S has made. He's finished for the evening but I'll make sure he gets your message when he's back in the office tomorrow.
Moderator
Moderator
Message 10 of 10
Hi @Guybrush3,
Sorry for the delay in getting back to you. @RobbieMac has tried calling a few times but hasn't been able to reach you. Are you still having problems? If so can you post further screen shots and ping details?
Cheers
David
