EWat
Message 1 of 1
Strong WiFi signal, very slow speed
We have Full Fibre 500, wifi speeds in the same room as the SmartHub2 are great (devices probably using 5ghz, 80mb/s or more)
The next room over? 0.25mb/s barely usable.
The kicker is - the signal is decent in that room -60db. I've scanned the local networks and set the hub to channel 11 for 2.5ghz (as it's totally empty).
Any ideas what's going on, or how to solve? BT helpdesk, unhelpful, and just keep trying to flog me their whole home discs for an extra £17 a month.
If it is a weak signal/interference issue, what would folks recommend? Mesh network/different router?
Thanks!
