Arkadius
Message 81 of 88
Re: Ping spikes despite new router and engineer visit
I might have a look into that as well actually. So if I wanted to turn off interleaving would I have to call up BT to get them to turn it off?
Keith_Beddoe
Message 82 of 88
BT have no control over interleaving on VDSL, it all automatically handled by DLM.
Arkadius
Message 83 of 88
Ah I see, and I'm guessing there is no way to change how the DLM handles it?
Keith_Beddoe
Message 84 of 88
No.
How does DLM (Dynamic Line Management) work (Plusnet page)
Arkadius
Message 85 of 88
Well that's dissapointing haha. Why would this be the case though? Looking on Zen's site you can actually opt out of interleaving: https://support.zen.co.uk/kb/KnowledgebaseArticle.aspx?articleid=10539. I would assume as they are using the Openreach network this option would also be available to BT customers?
Keith_Beddoe
Message 86 of 88
No, it says below.  Note:- BT can do it on ADSL.
NOTE: interleaving can not be applied/changed on the legacy fixed-rate services Home 500/1000/2000 and Office 500/1000/2000, or on Fibre Optic Broadband products.
Arkadius
Message 87 of 88
Ohhhh I see, gotcha, didn't see that bit haha. Oh well, I'll just pray to the internet gods that the line stays stable.
julien
Message 88 of 88
Hi
I have the same issue, and I am not gaming. You have exchanged a lot of posts. Did you find any cure for this problem please? Your help would be much appreciated.
Thanks!
