pippincp
Sage
Message 11 of 88
Re: Stumped by high ping spikes
RTT Round Trip Time. Basically how long it takes for the packet to get to the destination and the packet reciept acknowledgement to be sent back.
In simple terms a ping (packet) RTT of say 16ms would be 8ms to get to the destination and 8ms for the packet reciept acknowledgement (ACK) to come back.
BTW by all means come back on Tuesday and repost the stats or anytime you want. There'll always be someone to answer any questions you may have. Now, if you don't mind I'm off to bed.Smiley Very Happy
Arkadius
Message 12 of 88
Okay thanks for the explanation! Yeah I’ll make sure to reply to this thread once I run some more tests on Tuesday. Thanks for the help, I’m also off to bed!
Arkadius
Message 13 of 88
Just a quick update, I spoke to the letting agents for my house and they said they'd happily pay for the TD-W9970, I just have to send them the Amazon receipt. Whether or not this is going to fix the issue I don't know but after running some more tests today it does seem the high ping spikes are occuring somewhere down the line and maybe it isn't to do with the Home Hub. Again this test was done over a powerline adapter hence the slight jitter to the router:
Keith_Beddoe
Message 14 of 88
If you have other users or devices connected to your broadband, then that will affect the ping times, however with the TP link router, you can give your connection the highest priority (1), and configure the rest to lower priority (5 to 😎
You will need to make sure that your LAN IP address is reserved, as the priority rules are applied to the IP address, or range of addresses.
Example here Priority and bandwidth controls
Arkadius
Message 15 of 88
Okay that’s a useful feature, wasn’t actually sure if that router had the functionality.
Would this mean I would have to set my computers IP to static?
Keith_Beddoe
Message 16 of 88
There is no need to alter your computer, once you see the IP address you have been allocated, you can then reserve it, so it cannot be allocated to any other device. You will see your MAC address in the DHCP client list.
Look at the emulator https://www.tp-link.com/resources/simulator/W9970V2_Emulator/index.htm
Under the DHCP reservation menu.
You can do a manual IP allocation on your computer if you wish, but you would need to choose an IP address below the start of the DHCP allocations. (below 192.168.1.100)
Arkadius
Message 17 of 88
Ahh I see that’s useful! So it’s just easier to use the DHCP reservation method?
Oddius09
Message 18 of 88
Question who's dns servers are you using, BT or someone elses?
Here's a pingplot for me to 8.8.8.8, using a HH6a with Superfast Fibre 2 not as longer traces as yours but to give you a comparison.
Keith_Beddoe
Message 19 of 88
Yes, it works just fine, unlike the home hub which forgets.
If you were implementing parental controls, and did not want the user to manually change their IP address, then you can use the ARP binding option in addition.
Keith_Beddoe
Message 20 of 88
The example I give, uses OpenDNS, as I have an account with them so I can log which domains are accessed, and apply any controls.
You can use Google public DNS if you want.
If you leave the DNS to automatic, then you will get BTs DNS servers.
