Message 21 of 88
Re: Stumped by high ping spikes
Here are the DNS settings, assuming that they are BTs:
https://i.imgur.com/N1Y5fav.jpg
Message 22 of 88
Parental controls won’t be needed so yeah the DHCP reservation will work great!
Message 23 of 88
Yes.
Message 24 of 88
An example.
If you are allocated 192.168.1.100, then that can be allocated priority 1.
Then from 192.168.1.101 to 192.168.1.199, can be allocated a lower priority. Bear in mind that the guest wireless network is allocated priority 5.
The guest network is useful if you have visitors.
Sage
Message 25 of 88
@Oddius09 though I agree with you about DNS servers that is not the OP's problem.
DLM has taken action on the line most likely due to the number of resets done with/without his knowledge. This has caused an increase in latentcy and noise margin in an attempt to stabalise the line by DLM.
At present his RTT to 8.8.8.8 is 16-18ms which is about right based on his hub stats.
Like many who are unfamiliar with networks, diagnostics (no disrespect to anyone intended) and interpretation of tracerts and pingplotter, he's still fixated on the ping spikes en route which are immaterial to the end result.
Check the endpoint first and only if there is a problem there work backwards in the tracert/pingplot.
Message 26 of 88
Depending on your connection it can be set to interleaved ,or fasthpath this is set by BT will also affect you latency. interleaved will give you higher latency. You also appear to have a bridge tap which can cause issues.
Yes networking is one of those dark arts, I would start from the games server end as well.
Message 27 of 88
So how would I go about setting my ethernet connection as priority one and everyone else’s as lower? Nobody else in the house games or requires low ping.
Message 28 of 88
Cannot be done on the home hub. I have already explained about the TP Link router on this link
Priority and bandwidth controls
Message 29 of 88
Ahh I see, is there anyway to get BT to change it to fast path?
Message 30 of 88
Ah my mistake! Considering that I can get the TP link router without costing me a penny I’m definitely going to get it, also bookmarking this link!
