burtracoon
Newbie
Message 1 of 19
Superfast Fibre 1 with Smart hub frustrations
Hi there, I have been suffering intermittent performance issues with my network for as long as I care to remember but last night as finally pushed me to try and find a resolution and seek some assistance.
I have BT Superfast fibre 1 and a Smart hub  and BT TV.
On a good day all is fine and I get a 20mbps download which is acceptable however pretty much everyday I suffer from drop off's, massive latency  and buffering.  Performance drops to as low as 2mbps when doing speed tests. The lights on the hub all remain blue however a power down and restart of the hub appears to improve things for a short period.
Having gone through the BT online tests all is fine and apparently we recieve 20mbps to the hub, I have been through the telephone support in the past plugging into the main socket etc and apparently all is fine. (Apart from losing the will to live)
We use a number of various Iphones and Ipads, a couple of work laptops and a desktop, BTtv, smart TV, and a couple of internet enabled radios through power line adaptors.  Which all suffer the same.
My hunch is that the Smart Hub is the culprit but would like to confirm this before purchasing an new router (that will work with the BTtv.
Smart set up is turned off.
I just want a stable connection any help or advice most appreciated.
18 REPLIES 18
Message 2 of 19
Re: Superfast Fibre 1 with Smart hub frustrations
Welcome to this user forum.
It could be the home hub, as your report is similar to many others on this forum. You could ask BT to replace it, if you are still in a contract.
Have you tried a full factory reset of the home hub?
If you wanted to prove it, by substituting it with a different router, it would cost about £40, and will work with BT YouView, many others do not.
burtracoon
Newbie
Message 3 of 19
Thanks for the prompt reply.
In answer to your questions:
I have tried a factory reset which proides a tempary fix for upto a couple of days. Also swapped out filters, cables, etc etc.
I am still in contract so that could be an avenue, any tips on extracting replacemnt hardware? As never had much luck in the past.
Regarding a 3rd party router any tips of recommendations? Are they a straight forward set up, i.e. plug and play once you've added the broadband user name etc?
Techwizz
Message 4 of 19
Yeah, try asking for a replacement Hub, but you may actually be better with purchasing a 3rd party router. @Keith_Beddoe has vast knowledge in this area. But, a Billion 8800NL could be a good purchase for you.
Message 5 of 19
This one works just fine TP-Link TD-W9970
My daughter had exactly the same problem at her house, with the HH6, until I replaced it with the TP Link one. She has BT YouView, and it works fine. She has 48 devices connected, including many Smart devices. With the HH6, devices would lose Internet connectivity.
I would not be so sure about the Billion one that @Techwizz has suggested, as many of them cannot handle the BT YouView multicast stream.
The TP Link is very easy to setup, I have some help pages if you are interested?
Specification is here http://uk.tp-link.com/products/details/cat-15_TD-W9970.html#specifications
You can actually get it locally (Argos) or online.
Message 6 of 19
can you post stats from your hub advanced settings then technical log information
as hub light remain blue it would appear you are not dropping internet connection but connection from device to hub  as most of devices mention are wif did you split the networks
http://bt.custhelp.com/app/answers/detail/a_id/56419/~/how-do-i-split-my-bt-hubs-ssid-%28wireless-ne...
if you split networks then also select channels manually rather than auto   you can also try changing the wireless mode from 1 to either 2 or 3
burtracoon
Newbie
Message 7 of 19
I have tried splitting the network in the past and found it to have made litte or no difference, likewise the modes and channels have not altered performance.  Having read the forums they appear to be default things to try all of which had little or no impact.  I think if anything they cause a reset of the router giving a temporary improvement.
Message 8 of 19
I think you will find that the more devices that connect to the smart hub, the quicker the problem will occur.
Some connectivity issues are caused by the BT DNS servers, but you cannot change those on any of the home hubs, like you can on a different router.
Restarting the home hub simply clears out the DNS cache, and also gives you a different public IP address.
Message 9 of 19
splitting the networks, changing channels and wireless modes do no cause a reset of the router and many posts found splitting network helped improve their wireless connections
if you have tried that then try customer services and get a new replacement hub before trying 3rd party routers
burtracoon
Newbie
Message 10 of 19
Having entered into dialogue with the help desk they have a found a fault as described below.
"there is an important error I tracked while doing the test during we were chatting and found your service was in use for a long time which has clogged the connection profile resulting in intermittent drops thus I have done a refresher to the connection and will advise you to put a hold on the decisions regarding engineer booking or HUB replacement, please allow soe days to the HUB so that it settles with the new profile and then you can contact us back and we can then do a real time test to find any issue and will also look for an engineer visit who can also rectify any internal equipment issued"
"Since it is a residential connection your internet profile keeps changing (dynamic profile) and your HUB was using the same profile from a long time thus your connection was affected and we did a change to the profile now for a better connection."
Is this viable or am I being fobbed off as I feel i am?
