Message 1 of 4
Switching from VM to BT/EE
Current VM setup
Router address 192.168.0.1
Port forwarding for the following
DVR fixed IP at 192.168.0.99
NAS fixed IP at 192.168.0.138
When my BT/EE router arrives its my understanding that its default ip address is 192.168.1.254
Can someone give me the simplest solution to get my network up and running. Can I just change the BT/EE routers default gateway to 192.168.0.1 ?
Many thanks
3 REPLIES 3
Message 2 of 4
Re: Switching from VM to BT/EE
Yes, and also change the DHCP range to 192.168.0.140 - 192.168.0.254
Message 3 of 4
Many thanks,
Quick question regarding the DHCP range, i never did that on the old VM router, but I can see why you mention it. Is DHCP protocol that 'dumb' to allocate a conflicting ip ?, i never realised this, thanks again
Message 4 of 4
For starters, it will be in the wrong 192.168.1.xxx subnet unless you change it, and yes static IP addresses need to be outside of the DHCP pool to avoid conflicts.
