Message 1 of 3
Switching to full fibre
I have a Smart Hub2 and use BT Mini Connectors for various devices like computer, smart TV, Xbox etc. I am at present on BT Fibre 1. Full fibre has now become available.
If I switch
1. Will all my devices continue to work with above set-up?
2. If not what needs replacing and what will BT supply and at what cost?
3. Will the Hub to Mini Connectors still work and will I get full fibre speeds?
4. I am concerned that I may have to use WIFI which is passable in my house but I would not want to use for TV etc.
Regards
Terry Green
2 REPLIES 2
Message 2 of 3
Re: Switching to full fibre
@Bridterry
All existing devices should not be affected. The actual connection speed will depend on the capability of your devices.
Your home hub would be connected to the new Openreach ONT instead of your phone line.
If you need to retain your phone service, then it will be moved onto BT Digital Voice, and your phone will need to be connected to the phone socket on the back of the home hub.
Message 3 of 3
Thanks very much for quick and concise reply
