Tabu
Newbie
Message 1 of 2
Synology Nas DS212J BT Advance Hub 6
Hello,
I've just connected to BT and under my previous isp EE had no issues with connecting my DiskStation, I'm having real problems establishing a sync.
The diskstation shows up in the routers list of attached devises but does not allow me to sync, I've tried auto, and manual port-forwarding without success.
Is there a guide to connect to the nas using BT, as the synology guide doesn't.
Any help is appreciated.
1 REPLY 1
Tabu
Newbie
Message 2 of 2
Re: Synology Nas DS212J BT Advance Hub 6
For those who have been experiencing these issues here is my solution:
1 ) Unlink your cloud station see screen shot, hit ok
2 ) Re-link adding in the static ip for the cloud station
3) log in to your sysnology server
4) go to control panel > network > network interface (second tab at top)
5) select the connection your're using  (in my case LAN)
6 ) Edit the ip address of the router, BT SMART HUB 6 default is 192.168.1.254
7 ) Got to External access and check to see if it has connection
😎 Set up manual port forwarding on the BT HUB, as sysnology has not updated it's settings for HUB 6.
Hope this helps others
