Message 1 of 3
TP-LINK
Hi, will i be able to rig up a tp-link kit to my home hub router easily,its a TL-PA401OP model,is it just a case of pairing the 2 plugin connecters ,then plug an ethernet cable from hub to the main plugin which will feed the wifi (hopefully) thru to the 2nd plugin in another room,and will i need to use the WPS button . Am a bit green on all this plus the instal guide is missing from TP LINK box as its been " donated " to me .
2 REPLIES 2
Message 2 of 3
Re: TP-LINK
they should already be paired so plug one in near hub and connect to hub with ethernet cable then plug other in wherever you want it and then conenct ethernet to device
Message 3 of 3
Re: TP-LINK
Many thanks for the info.
