Message 1 of 5
TP-Link RE300 Range Extender & Smart Hub Issues
I've recently installed a range extender so I can get a signal to my garage. All worked okay for a week or so but has now started to flag up IP issues. Please see attached picture for details. Basically it works okay for a day then I can't log on to the extended network, getting an 'IP Configuration Failure' error.
Only way I can find to sort this is to restart the BT router, but that's obviously not a long term solution.
Please help!
4 REPLIES 4
Message 2 of 5
Re: TP-Link RE300 Range Extender & Smart Hub Issues
@Craigdm66
Welcome to this user forum.
The default gateway address is wrong.
I suggest that you configure the extender with static network settings. Use the option to specify the network settings.
IP address 192.168.1.50
Subnet mask 255.255.255.0
Default gateway 192.168.1.254
DNS 192.168.1.254
I have specified an IP address outside of the DHCP range, to avoid it clashing with any other device.
Also, make sure you disable smart setup on the home hub.
Message 3 of 5
Thanks for the prompt reply.
I've updated the extender as you suggest and will report back if this cures my woes!
Message 4 of 5
@Keith_Beddoe
I tried the setting as your suggested and it worked fine for a day, but now when I try to log into the extended network I get a connection, but without internet.
Any more ideas?
Message 5 of 5
No really. Wireless extenders are never the best solution, and are usually unreliable and reduce throughput by about half.
Separate wireless hotspots with a different SSID, are normally the best option, without resorting to a wireless mesh.
https://shop.bt.com/products/bt-mini-wi-fi-home-hotspot-600-kit-084288-BVFF.html
