cinek
Message 1 of 2
TP-Link TL-WDR4900 N900 to replace hh3?
is the TP-Link TL-WDR4900 N900 any good as a hh3 replacement? Will it be able to achieve the same speeds? I recently had the asus n66u which was maxing out at 200mbit which is no good ;/
1 REPLY 1
cinek
Message 2 of 2
Re: TP-Link TL-WDR4900 N900 to replace hh3?
just FYI if any1 is looking at this, I borrowed one from a friend and I'm able to get 280mb which is much better than the asus n66u (it was maxing out at 200mb)
I'll see how it gets on for a couple of days
edit: just tested wifi on my laptop and it's no good, I only get between 12-16mb down, with hh3 I get 53mb
already tried changing channels but it didn't help 😞
