A year ago I found a link to settings for the TP Link router, I think it was Keith Beddoe?
I need the settings again as I had to hard reset the router, I can not for the life of me find the link anymore. Can anyone please help out?
TIA
use the quick setup and select BT and username bthomehub@btbroadband.com and password bt
are you on fibre? if so you must be using a modem in conjunction with your hh4
the tplink should be connected direct to the master socket and miss out the modem
if you are on adsl then should be set to PPPoA not PPPoE
FTTC is fibre to the cabinet and the standard existing copper wire from cabinet to your home but at 4 miles more likely to be adsl
Select BT ADSL in the quick setup menu, not VDSL or Infinity
