Gurds
Newbie
Message 1 of 9
TP Link archer vr2600
I've just had my broadband upgraded to infinity and my modem no longer works with infinity. I've changed the settings to BT VDSL but it just won't connect. I've been in touch with tp link and they said that the modem might be faulty and have sent me a new one. The new one doesn't connect either, but as soon as you plug the homehub, the internet is back up and running. Has anyone else had difficulty connecting the Archer vr2600 with infinity?
8 REPLIES 8
Message 2 of 9
Re: TP Link archer vr2600
Have you entered the username as homehub@btbroadband.com and password as BT?
Gurds
Newbie
Message 3 of 9
I've tried leaving the password blank and also used BT but still noting.
Gurds
Newbie
Message 4 of 9
It was working fine on ADSL
Message 5 of 9
No reason why it shouldn't work, its not a generic problem with the router as others are using it succesfully. Try a factory reset and start again using the quick setup.
Gurds
Newbie
Message 6 of 9
Should it work of the quick setup or is there additional things that need to be added
Message 7 of 9
It should work with the quick setup if you select BT VDSL and correct username and password.
prinknash
Expert
Message 8 of 9
I have a VR600 rather than VR2600 but I think the UI is similar.
Have you checked (under Advanced - Network) that the DSL mode is VDSL and the VLAN ID is 101? And the connection type is PPPoE? If you'd done all that and entered your PPPoE Username and Pasword as mentioned above, it ought to work.
(I know telling you it ought to work isn't necessarily very helpful ...)
p
Gurds
Newbie
Message 9 of 9
Checked everything and still can't get it working. It comes up with "internet not connected. Please check if your phone cable is properly connected"
