Message 1 of 3
TP Powerline Extenders / BT Mini connector - Use TWO port BT as extended connection
Hi,
Probably been asked before, (I did have a search but didn't spot anything so far)
I have received two SINGLE port TP Link Extenders and a (one)  TWO port BT Mini connector.
What I want is to use a TP SINGLE port unit as the Base/Router connection and the BT TWO port unit in a room with two devices. (an IMac  and a HP Desktop PC)
This would be a great solution and use of available kit/ports.
I will be assisted, (I am visually impaired - but can type and do a range of tech activities) and we will go through the two instruction guides.
Is this workable?
j
inanity.co.uk
2 REPLIES 2
Message 2 of 3
Re: TP Powerline Extenders / BT Mini connector - Use TWO port BT as extended connection
In theory it would work but usually using Powerline adaptors of different brands/makes do not work well together.
Best thing is to try it and hopefully they play nice together.
Message 3 of 3
Hi
Well BT supplied all the kit as one bundle - I will have a read and give it a go.
Then report back 🙂
inanity.co.uk
