Message 1 of 3
TPLink powerline adapters casuing wifi internet access dropout
Good evening all,
I have TPlink powerline adapters. Full fibre and BTHomeHub2
I have been living with internat acccess dropping out several times per day for may be 8 years.
I have feebly complaned a few times and got nowhere.
Light bulb moment.. Could it be th eTPLink stuff?
Let's turn off the TPLink adapters - No wifi dropouts all day. My suspicions are aroused....
Parts of the house not reached by the hub
What can I do to make my TPLink adapters work without casuing dropouts, please.
Or are you all laughing up your sleeves becasue you all knew about this years ago?
Many thanks in advance
Tom
2 REPLIES 2
Message 2 of 3
Re: TPLink powerline adapters casuing wifi internet access dropout
On xDSL connections, using powerline adapters when the phone line runs close and parallel to a part of the ring main can very definitely be problematic.  Some powerline adapters have a setting that can reduce the problem but they won't always eliminate it.  Sometimes it's just enough to remove any wire phone extensions!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 3 of 3
Thank you so much - I'll try reconfiguring my cable geometry...
