Egbert
Message 1 of 4
TV code
Where do I find the right TV code so that I can set up my remote control?
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: TV code
Hi @Egbert and welcome to the community.
Thanks for posting. Are you trying to connect the YouView remote to your TV? What type of TV do you have? Can you confirm the make and model and we'll try to help.
Cheers
David
Egbert
Message 3 of 4
Re: TV code
Thanks for replying, but I seem to have magically connected, though I don’t know how! My TV is A Blaupunkt, and there seemed to be several lists all giving different codes, but I must have eventually hit upon the right one.
Moderator
Moderator
Message 4 of 4
Re: TV code
Thanks for getting back @Egbert .
Glad to hear you got it sorted.
Cheers
David
