Message 11 of 16
Re: Techie question. How do you clear Hub Manager (via browser) cache?
Thanks, good point. If I’m the only one who has access to the hub then I’m the only one who sees them.
I guess I was just looking into this to see if it was / is in any way a issue.
Message 12 of 16
It isn't.
Message 13 of 16
Why not?
Message 14 of 16
Thanks, WSH, that helps, much appreciated.
Message 15 of 16
@murray451wrote:
Why not?
Only you have access to the list and it is of no use to anytbody else. All it is doing is telling you what device connected to your hub and when it did this.
If you are concerned that the devices that are on this list could reconnect to your hub without your permission, change the wifi password.
If you want to clear the list just factory reset the hub.
Message 16 of 16
Thank you gg30340.., appreciated…,
