AjayK48
Message 1 of 7
Text back on 61998 after reporting a fault
Not really sure where to post this so apologies if it is in the wrong place.
When reporting a fault with my Broadband and an engineer is booked to visit I get a confirmation text back confirming the appointment. It comes from number 61998 and asks you to reply if you need a call back, need to change the appointment / cancel etc.
When I use this facility and reply to the message on 61998 I just get a message "Sending Failed" each time. I mentioned it to the call centre and they stated everything was working ok and they had not had this reported before. I have had exactly the same problem 3 times now in trying to respond to texts from BT on different occasions.
Has anyone else had this problem. My mobile phone is on Virgin Media PAYG.
Thank you.
6 REPLIES 6
Rottie
Expert
Message 2 of 7
Re: Text back on 61998 after reporting a fault
Thank you.
It's most likely your network that's not allowing you to send those texts. I used to have the same problem if I tried texting certain numbers, from my old phone, which was PAYG on Three.
ChrisKFP
Message 3 of 7
I am having the same problem, I need to reply to the text but I get 'sending failed' each time.  I'll have to phone BT tomorrow so will mention it too.  Am on Orange/EE PAYG.
ChrisKFP
Message 4 of 7
After checking elsewhere online, I wrote a new text and sent it to that number rather than replying to the BT text, for some reason that has worked.  I have no idea why this makes a difference!
BenGun
Message 5 of 7
I managed to reply to a text from 61998 but was surprised to see that it had cost me 20p!   Anybody know why I was charged when part of my package is unlimited free texts.  Closer inspection showed that I was charged 2*10p for the single short text.
Julesjam1
Message 6 of 7
Cannot believe BT charge a premium rate text service that isn't included in mobile packages for
replying to their text for a fault. Very dissapointed
MrBeanz
Newbie
Message 7 of 7
Broadband went down over Christmas as a result of floods in York - reported and said yes to text update (mistake!). So BT sent a premium rate text from 61998 (10p) to tell me they've fixed the broadband which I'd already found out as my computer had already re-connected.
The amount is small but no doubt BT makes a nice profit from thousands of these. I'm not aware of being told the response was premium rate and that my mobile provider (Three) might charge.
Just leaves a nasty taste in the mouth. So BT charges customers as part of the process of fixing a problem - yes the floods were not BT's fault but inadequately protecting essential equipment in a flood risk area is poor management.
