Message 1 of 4
Theoretical ethernet broadcaster device
If I connected an ethernet cable from my bt router, what device would take that ethernet input and broadcast it as a wifi signal in a new place?
3 REPLIES 3
Message 2 of 4
Re: Theoretical ethernet broadcaster device
A wireless access point, or a spare router used as a WAP.
Message 3 of 4
an old router
Message 4 of 4
You would need to buy a separate wireless access point like the TP- Link TL-WA801ND and connect it to a spare Ethernet port on the home hub, once its been configured. It works very well, with a good wireless range. Make sure you configure it correctly.
