superuser
Message 11 of 21
Re: Third party router with FTTP
my speed sometimes drops down to 250 at times but its a shame that the signal is so weak on 5hz but most of my kit is wired in, my router is the r8000 tri-band so if your thinking of changing then at least you will know it will run those speeds you have
Sumpte
Message 12 of 21
The R8000 has a different processor (though, on the face of it, it's 1Ghz dual core instead of the R7800's 1.7Ghz dual core?) so it must be able to handle processing the modem data better. Right now I'm managing OK with the SmartHub, but good to know the higher end Netgear's might be able to handle the speed.
wii89
Message 13 of 21
I am using the ONT connecting to a Unifi Gateway USG-3 using PPPoE connection and its working perfectly no speed issues for me.
1nf0
Message 14 of 21
Going to upgrade shortly. Want to ditch the Bt router for the same reasons. How are you getting on now. Bridging from the Bt router is a non starter for me.
ive got a ASUS RT-AC86u which is beefy enough. Hoping it’ll be plug and play. Did changing the MTU help.
markbloke
Message 15 of 21
With regard to the R7800, I'm using one now with BT 330Mbps FTTP and am experiencing no problems at all achieving full speed. Perhaps the firmware has been updated since this thread started.
CarlyNita12
Message 16 of 21
Hi
i am about to try and install USG
what credentials did you use for FTTP
any tips?
CarlyNita12
Message 17 of 21
Can you guide me on install of USG?
wii89
Message 18 of 21
Just use
username, bthomehub@btbroadband.com, you can leave the password blank.  or use bthomehub
CarlyNita12
Message 19 of 21
Thank you
any technical issues to worry about?
I have those details in the USG and set it to pppoe
dod I have to do anything.. power cycle ont or anything?
wii89
Message 20 of 21
connect your usg wan 1 port to the fiber modem on the wall, and Lan 1 to your switch or pc
enter the settings for ppoe connection and wait a few mins and it will connect. I have the same setup and its working perfectly
