Message 21 of 98
Re: Tidal drop outs and not finishing tracks
@womaz wrote:
It was a sky hub
Thanks.
I think at this stage we need to prove whether it is the home hub causing the stream breaks, by looking at the event log.
I do know that people have reported compatibility issues with the Smart Hub.
The only way to prove if that is the case, would be to use a different router, there are plenty of options, prices starting at £30 locally, and can be returned if they do not help.
Your actual Internet connection would come from the same cabinet and use the same line, so I don`t think its a line issue.
womaz
Message 22 of 98
Yeah that makes sense.
The reason I assumed it was since my switch to BT is Tidal worked ok with Sky. it was the very same day that I got BT that the tidal issues started.....just too much of a coincidence for me.
Again thanks for the help
Message 23 of 98
I think we just need to identify whether it is the home hub, as everything is pointing to it at the moment.
I do not use a home hub anymore.
I assume your download and upload speed is fine, using the BT Speed tester?
http://www.speedtest.btwholesale.com/
womaz
Message 24 of 98
Yes the speed is excellent 42MB and upload about 17
Message 25 of 98
Then it may just be an issue with the home hub. If it continues, then try a different router, its very easy to do, and not expensive. I have all of the details.
womaz
Message 26 of 98
Three weeks later and I am still having the same issues.
BT chat helpline was not helpful at all...so I have raised a complaint.
My line is fine as it has all been checked. Other than buying a new router i dont know what to do, but surely after signing up for an 18 month conttract BT supply me with a suitable router? Not so sure I should be put to additional expense
I will cancel and go back to Sky if they camt help..........I assume I can get out of the contract becasue of these issues
Message 27 of 98
@womaz
You could try a diiferent router for £30, and then return it if it does not fix the problem. You have nothing to lose.
Menu item 5 on Forumhelp
womaz
Message 28 of 98
I may have to do this if BT dont help me. Its just not sure it will solve it and returning stuff is a bit of hassle.
I would pay £200 for a really good router if I knew it would solve the issue.
I assume all routers can be used with a different provider if I move from BT
Message 29 of 98
Argos, PC World and Amazon sell that one, and yes you can use it with other providers if need be.
Spending £200 is a bit much just to prove the issue is the home hub, I would just spend the £30 and see if it cures the problem.
womaz
Message 30 of 98
I am not that good with tech stuff. so I assume I just unplug my router and plug in the new one? No need to do settings etc? Or is it not that simple
