womaz
Message 51 of 98
Re: Tidal drop outs and not finishing tracks
Time and date
Message
Selected:  ALL
11:41:09, 07 Feb.
BR_LAN:The DHCP options that are offered by the device (id:4): DiscoverOptions: | DiscoverOption55: | RequestOptions: 53,55,57,61,50,51,12 | RequestOption55: 1,121,3,6,15,119,252 | HostName: iPad | VendorId:
11:41:09, 07 Feb.
:DHCP Confirmation of Request
11:41:06, 07 Feb.
wl0:A WiFi device <B4:F6:1C:50:D8:8B> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
11:40:02, 07 Feb.
:HTTP UserAdmin login from 192.168.1.67 successfully
11:37:23, 07 Feb.
:HTTP UserBasic login from 192.168.1.67 successfully
Message 52 of 98
womaz
Message 53 of 98
I have copied and pasted above
The skipping of the tracks occured at about 11.45 and dont show
womaz
Message 54 of 98
The reason  I am reluctant to buy the router is I am not sure if it is just a problem with Tidal.
It happens at the same time every time on certain tracks. This indicated it is not packets of information dropoing out......but hey I havent got a clue really.
Tidal now just sweeping this under the carpet
Message 55 of 98
It does seem like a Tidal issue, but you say it work on wireless without any problems, so it cannot be cause by them.
womaz
Message 56 of 98
Yes it works on my portbale device. This is a wireless connection and I dont have any issues with the end of tracks.
On the odd iccasion it does drop out, but its rare.
If it is a Tidal issue the new router wont help. And it is only on ceratin albums. Others work fine
I have spent so much time trying to sort this issue.....it is so frustrating
womaz
Message 57 of 98
I did the ping test.....no idea what it is but I did it
Download 70MB
Upload 19MB
Ping 19ms
Jitter 0.34ms
Loss 0%
womaz
Message 58 of 98
One last question before I take the plunge on the new router
Is this a better router than the smart hub?
I am wary i cause other issues if I go for a new router as I run my own buisiness from home and no connection means no work gets done
Message 59 of 98
Its a much simpler router, and seems to give less problems from the home hub in some cases.
As for running a business from home, you are breaking the BT Residential T&C by doing that.
womaz
Message 60 of 98
I did not know that. I am a sole trader, so did not realise this was an issue
