Mikelloyd
Message 1 of 4
To link smart plug
I can't connect my TP link smart plug to my smart hub it just doesn't get recognised
3 REPLIES 3
Keith_Beddoe
Message 2 of 4
Re: To link smart plug
Mikelloyd
Message 3 of 4
I have separated channels and turned off smart setup. To reset hub do I just turn off and on or need to unplug?
licquorice
Message 4 of 4
Neither, you need to press the recessed reset button with a paperclip for 20 seconds until the lights flash.
You will need to turn off smart setup and split the wireless again afterwards.
