Message 1 of 15
Totally baffling WiFi issue
Hi everybody
I have a totally baffling wifi issue
Briefly I have a BT HUB 5 and an Apple iPhone 8
If I place ny iPhonw within a few feet of the Hub in clear sight  I CANNOT get a connection
However If i take my phone into another room several feet away with a wall between the phone and the router I get a stable connection.
This is intensley annoying as my router is in the lounge but to use the phone I have to go into the other room which is the kitchen where the phone is behind a wall and has NO clear sightt of the router
This seems to break all the rules of router placement and clear line of sight to connect devices
PLease any theories as to the cause of this totally baffling issue
Thank you
Regards
Edward
14 REPLIES 14
Message 2 of 15
Re: Totally baffling WiFi issue
First a reminder that you did ask for theories, to that end Sky Q comes to mind
If you have Sky Q in close proximity to your hub and your hub is using channel 36 then  it could be that there is a beat frequency between the two of them which is interfering with your iphone when it is in close proximity to them both and this becomes less of a problem as you move your iphone further away.
The solution, if this was the case, would be to change the 5GHz channel that your hub is using to any other
Message 3 of 15
Hi Les
Thank you for your theory
I dont have Sky Q but I can see where your coming from
I have downloade a WiFi scanning app and am shocked by what I found
There are numerous WiFi sources picked up  including of course my own router but what has really surprised me is that there are several VERY strong signals notably listed as BT WiFI or BT WIFI X
I have also picked up rxternal BT Hub5 and BT HUB6 and external Sky TV sources
In fact a real mish mash of external sources.
Do you think these external sources could be the source of my issue and if so is there any thing I can try to block them?
Anonymous
Not applicable
Message 4 of 15
You can't block WiFi but your WiFi analyser should be telling you which channels the other networks are using, so switch your router to manual & select channels with least congestion. For 2.4GHz it's best to stick with one of the primary channels 1, 6 or 11. As @Les-Gibson said, avoid channel 36 for the 5GHz & anything else with a strong signal.
Ignore the BT WiFi, that's just the public network broadcast by your router.
Message 5 of 15
@efelstead
It could be that these very strong signals are causing interference or it could be that there is a problem with your phones selectivity (in a nutshell the tuned circuits which accept one channel and rejects others).
The best way to test would be to try another phone (preferably a different make and model) and check if that suffers the same problem.
Anonymous
Not applicable
Message 6 of 15
If you haven't already, it may be worth splitting the WiFi bands on your Hub.
https://www.bt.com/help/broadband/fix-a-problem/broadband-and-wi-fi/i-want-to-improve-my-wi-fi/how-d...
Message 7 of 15
Either the hub or the phone could have a problem with the 5Ghz wifi, which the phone will use when close to the hub, but ok on 2.4Ghz which is probably being used in the other room.
Have you tried changing channels?
Message 8 of 15
Thank you all for the posts - very much appreciated
More information to add and a furtther request for opinions
First my WiFi scanner reports my Hub is using Channel 1  at 2.4Ghz
There is no signal at 5GHZ
I am not conversant with channel splitting so will have to study the links provided (Thank you)
I am seeking opinions about switching from
WiFi to an Ethernet connection to my phone as I have a spare connection to the hub and can easily get the
necessary connectors
If I do this what functionality of the phone could I potentiality lose?
Thanks again for your help and I look forward to your opinions about using an Ethernet connection in place of the rather flaky and unstable WiFi
Message 9 of 15
Thanks for the post
Your comments about 5ghz do seem relevant as the Wifi scanner I am using does not pick up a signal at 5GHZ
I will look at that again maybe I have'nt set up the scanner correctly
Message 10 of 15
That seems to confirm there is a problem with your hub's 5Ghz signal. If you give the 2 bands different SSIDs (network name) then you can choose which band your phone connects to.
