Message 1 of 2
Tp linkArcher AX73- AX5400
Hi. I purchased a Tp linkArcher AX73- AX5400. I've connected it to my BT Smart hub. My download speeds are 66 -73 Mbps. And upload speed is 16-17 Mbps.
How can I get higher speeds.l on the Top link.  It's connected to auto.
Hope someone can help.
1 REPLY 1
Message 2 of 2
Re: Tp linkArcher AX73- AX5400
@AA3444 you could already be getting the most out of your connection. Depending on the technology that delivers your broadband connection there could be limitations based on distance and quality of the cable if on copper based line from the cabinet.
What does https://www.broadbandchecker.btwholesale.com/#/ show for your line?
