Message 21 of 27
Re: Tplink router for BT fibre
Thanks, i'll give that a try when I get chance later - it was set to Auto earlier. I've also noticed there's an option for turning the 3g/4g backup off so will try that too and see how it goes
Message 22 of 27
I tried the authentication to CHAP but that didn't make any difference switching off the 3G/4G functionality didn't seem to help either. I did check the logs on the router and found the following:
2019-09-23 13:56:21 [6] PPP: ppp0 sent [PADI Host-Uniq(0x0000115a)]
2019-09-23 13:56:39 [5] DHCPD: Recv INFORM from 10:65:30:14:00:9B
2019-09-23 13:56:41 [3] PPP: ppp0 Timeout waiting for PADO packets
2019-09-23 13:56:58 [6] PPP: ppp0 sent [PADI Host-Uniq(0x00001257)]
2019-09-23 13:57:03 [6] PPP: ppp0 sent [PADI Host-Uniq(0x00001257)]
2019-09-23 13:57:13 [6] PPP: ppp0 sent [PADI Host-Uniq(0x00001257)]
It seems to be timing out for some reason but i've no idea why. I've posted on the TPlink forum too so will see if they respond. Other than that I think I might be returning it
Message 23 of 27
After posting on the TPLINK forum they suggested removing the VLAN tick which seems to have fixed the problem! 🙂
Message 24 of 27
Thanks for updating the thread. Glad you got it sorted
Newbie
Message 25 of 27
Tplink has to be in wireless router mode.
Message 26 of 27
You are replying to a 6 month old post that has been resolved
Newbie
Message 27 of 27
I couldn’t set it up with the solution!! I had to set it up this way!
