Message 1 of 7
Trying to connect new mobile to BT internet
We have just purchased a new Motorola Go6 mobile and are trying to set it up to connect with our home's BT internet. The phone recognises the hub and has a list if all the hub information on its Wifi page. However the note says "- security, strong - Connected / No internet access". All other devices around the house that use internet are connected and working as usual, so its not a broadband issue. Another phone recently purchased as a gift for family member connected without a problem.  I don't understand why this time it hasn't been straight forward. We have obviously put in the correct password, etc. to get as far as we have.
6 REPLIES 6
Message 2 of 7
Re: Trying to connect new mobile to BT internet
Have you tried restarting the phone?
Message 3 of 7
Have you actually attempted to connect to the internet?  I've known new connections to initially report no access and then that disappears when you attempt to connect to a website.
Message 4 of 7
Yes, a number of times. And disconnected & reconnected the hub hoping that would help 'discover' the phone.
Message 5 of 7
Not quite sure why you are asking on here, the problem is clearly with the phone not the BT hub.
Message 6 of 7
Hi @Harricobean
It could be a device conflict with the IP being assigned by the router. This would explain the Wi-Fi showing a connection but not actually serving the web to you.
Please restart the router and your mobile device at the same time, and wait 5 minutes or so.
You may need to do this twice.
Keep us updated with how you get on.
Ali
Message 7 of 7
Aki A
I have tried both if those options ...... but not together!   I'll give that a go.   Thank you.
