Alnorwich
Message 1 of 3
Tuya smart app wifi connect.
Anyone managed to WiFi connect Tuya smart app. to a BT smart hub 2? If so how. I can see how it can be done with earlier versions on the hub but....!
2 REPLIES 2
NeilO
Moderator
Moderator
Message 2 of 3
Re: Tuya smart app wifi connect.
Hi @Alnorwich, welcome back to the community and thanks for posting, I can't give you specific advice on the Tuya app but I have seen problems like this being resolved by turning off Smart Setup on the Hub.
Neil
Alnorwich
Message 3 of 3
Thanks, I'll give it a try.
