A4ron87
Message 1 of 2
Two Xbox ones party issue BT hub 6
Hi I have two Xbox ones connect to the BT home hub 6. When both in party one allows and the other Xbox says disconnected won't allow. Can they both share the same port etc that may be the problem. Has any one else had the same issue and how to resolve it. Thank you
Tags (1)
1 REPLY 1
