dr-joolz
Message 21 of 35
Re: URGENT: Nexus 7 2013 will not download anything from the App Store
I have exactly what you described here
PaddyC13
Message 22 of 35
Hi Folks,
I also had Google Support in California working on this problem for most of Friday afternoon.  They were amazing, I logged a callback and in less than 1 minute, Chris phoned me on my mobile from the USA!  Chris checked everything on my Google tablet and account and could not find anything wrong.
So in summary, my position is as follows:
1. Problem affects all Android devices in the house, each has a diffrenent Google account and Android versions.
2. The Android devices can acces and update from the Play Store if using mobile data ratherr than WiFi.
3. Changed my BT HH6 for a TP-Link router and the problem persists - not a BT router specific issue.
This would lend me to believe the root cause it at BT's end somewhere.
I will post anything I hear from BT and/or Google.  I am sure we will get this resolved.
Have a good weekend.
Many thanks
Paddy
Moderator
Moderator
Message 23 of 35
Hi guys,
Thanks to those of you who've sent us over your details.
I've passed this off for investigation.  We'll post the outcome on this thread as opposed to coming back to you individually.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
PaddyC13
Message 24 of 35
Hi Robbie & Noel,
Some additional information for you.  We visited TESCO Cafe this morning and used their WiFi.  We took my Nexus 7 and my daughters Android phone to test.  The two devices are using different versions of Android and Google accounts.  Both accessed the Google Play Store and updated successfully via TESCO WiFi.
The problem only seems to exist when accessing the Play Store from home via my BT broadband.
Hope this helps.
Paddy
dr-joolz
Message 25 of 35
I also confirm the same . When I tether my o2 data to my taboet the tablet can also update fine. As soon as I'm back on my bt wifi - fail
dr-joolz
Message 26 of 35
Right now YouTube is failig to update and hukd (hot UK deals) app is failing to install. I can get on my dad's sky wifi at  his place and update / install these fine.
Then my dad comes to my bt wifi and cant install / update either, so something is wrong with bt for sure where sky has no issues
Moderator
Moderator
Message 27 of 35
Hi all,
We've had an update from our network tech guys confirming this should be sorted. Can you check this at your side and let me know if there has been any change?
Cheers
David
Community ModeratorDaveM
Kudos”Kudos”
dr-joolz
Message 28 of 35
Nope nothing has changed unfortunately…
Moderator
Moderator
Message 29 of 35
Thanks for getting back @dr-joolz. Sorry there's no change at your side. I'll feed that back. Thanks for checking.
Cheers
David
Kudos”Kudos”
Wizzerzak
Newbie
Message 30 of 35
No change here either, thanks for looking into this.
(Tried rebooting phone/router too).
