helzapoppin
Message 1 of 12
USB port
Can you use the USB port on the smart hub   to play music from a usb stick,
using a Sonos playbar if yes how do you set this up.
11 REPLIES 11
albertj
Recognised Expert
Message 2 of 12
Re: USB port
Hi,
Yes, the USB port on the back of the Smart Hub can be used to share files. By default it uses the address: 192.168.1.254.
You can use this guide from Sonos, showing how to connect: https://support.sonos.com/s/article/78?language=en_US
The share is \\192.168.1.254, you can access this on a Windows PC to see the shared folder, if Sonos can’t find it itself.
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
helzapoppin
Message 3 of 12
Re: USB port
I typed \\192.168.1.254 in the share info page on the music library
sonos set up music share.
it said Sonos can’t find this share, I tried putting in the admin password for hub manager
on the next attempt again it said Sonos can’t find it.
just tried it again and nothing happens at all now.
i have looked on my pc and I can’t find it there.
i have looked in the bt hub and the usb is showing there has
storage device on port 1 usb
albertj
Recognised Expert
Message 4 of 12
Re: USB port
Is your network set as Private on your PC?
If you type //192.168.1.254 into your PC does it find the share?
licquorice
Message 5 of 12
Re: USB port
Your slashes are wrong direction
Try mapping a drive to  \\192.168.1.254\usb1
imjolly
Message 6 of 12
Re: USB port
If sh2 then USB format needs to be FAT32 not NTFS. There is a large thread about this already
licquorice
Message 7 of 12
Re: USB port
Don't understand why, but I think FAT32 is only needed for hard drives, I can read an NTFS formatted usb stick just fine on a SH2
helzapoppin
Message 8 of 12
Re: USB port
I removed one album from the usb stick which I downloaded from the iTunes store( format
wma) then I type in \\192.168.1.254 on my pc the run command come up and it works.
but still no joy getting to work with sonos app on my ipad (file share)
imjolly
Message 9 of 12
Re: USB port
@licquorice
USB port problem ongoing for weeks
https://community.bt.com/t5/BT-Devices/Smart-Hub-2-and-USB/m-p/1949824#M9018
albertj
Recognised Expert
Message 10 of 12
Re: USB port
Oops, yes. Thank you
