Message 1 of 2
Ubiquiti AmpliFi connection issues
Hi, i have what i believe is FTTC, and i was provided with the homehub6.
The range wasnt good enough, so i got a white openreach modem (huawei) and linked it up to a netgear router.
I used the login details U:bthomehub@btbroadband.com P:BT, all was well but range still not good enough...
I tried Tenda mesh system, logged in PPPoE with same user details, all was well but Tenda system was **bleep**..
I have just purchased the Ubiquiti Amplifi system but struggling to connect.
I choose PPPoE with the same user details, sometimes works sometimes doesnt. First time it worked for 5 mins. I ended up doing a factory reset and then it worked for 30mins, before dropping off again.
The error it gives me is please varify IPv4 configuration.
Any help appreciated!
1 REPLY 1
Keith_Beddoe
Message 2 of 2
Re: Ubiquiti AmpliFi connection issues
Welcome to this user forum.
Please see this post from @mike000 another forum member using the same system, they may be able to help.
https://community.bt.com/t5/Home-setup-Wi-Fi-network/BTHub-5-and-BTHub-6-Wifi-5Ghz-issues-update-rel...
